Charging cable
(Topic created on: a month ago)
MalshaDew
Is the charging cable included with the phone box a 3A cable or a 5A cable? 🤔🔌
2 Solutions
I'm not sure which device you are asking about. Upto the s24, the cable was a 3A, and with the s25, it's upgraded to a 5A. I hope this helped?
If my comment helped you figure things out at all, please consider tapping the three-dot menu and mark it as a solution. Your support fuels the community! Thanks for being part of it!
If you read my comment the answer remains the same.😊
7 Comments
MalshaDew
Samsung s24 ultra
MalshaDew
Thanks🙏
My pleasure!
Janith842
The S24 Ultra and S25 Ultra both get the same 3A type C to type C cable in the Box. But if you take a original 45W Adapter with that Adapter the cable comes with the 5A. But in the Box for S25 Ultra Samsung has included the 3A Cable.
If my comment helped you in any way. Please consider hitting the 3 dot menu of my comment and accept it as a solution. It would be helpful for me a lot.
Thank you 😊
Janith842
Whe we take External Original Adapters. With the 45W Adapter there are 2 types of Cables. Both 3A and 5A cables comes with the Adapter Box. The 5A Cable with the 45W adapter is a bigger box than the other. Hope your point is cleared Bro.
