Charging and network issue..
(Topic created on: 07-04-2024 11:52 PM)
Autohunter_at7krpm
Hello,
I have a Samsung S22 Ultra. It's not charging with the 25W fast charger and doesn't support USB Type-C to Type-C cables for data transfer and charging. When using a normal 15W USB to Type-C cable, the phone charges and transfers data very slowly. Im also change the cable and adapter but its not working. Additionally, after restarting the phone, it sometimes fails to detect the SIM card for a few days before resolving itself automatically.
So what is the problem.? so please anyone help me to solve this problem.
5 Comments
goodthings
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time, restart your's device without any Sim in slots, interchange Sim in slots, turn off power saving mode then try to it's again also charge your's device in cool atmosphere also during charging turn off internet then try to it's again. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
I'm done everything alright but it's not working 😢
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your query, we would request you kindly visit the service center and inspect your device with the technical team end, they will provide you with all the information in a better way after inspecting the device physically.
You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
