Charging Port Problem
(Topic created on: 08-10-2024 01:58 PM)
Babar19384
Hi .. I just bought a Samsung S10 today and it has some charging issue . It is showing this Warning sometimes ( not every time ) when i plug in the charger .. I have tried changing the charger and cleaning the charging port .
Can someone who had faced the similar issue tell me whats wrong and how to fix it ?
5 Comments
Bhai service center yaa phirdukaan check kar waa loocharging portclean kar dein gaaay woh
aakashnawab7
Charger mei, ya charging port mei moisture hai. Is wajah se error aa rha hai.
Solution: Carbon Tetra Cleaner (CTC CLEANER) Ki bottle milti hai bazar se. Mobile Market mei easily mil jaegi 100Rs ki.
Wo liquid aap charging port mei spray krein. Usk baad paper fold krk, ya kpra fold krk charging pin ko saaf krein ander se. (Tissue paper se saaf na krna, otherwise usk particle reh jaeinge ander). Ache se saaf krne k baad mobile ko 2,3 hours rkh dein. Hawa mei. Ya sunlight mei le jaein, lekin mobile ko sunlight mei na rkhiyega. Hath mei aese pkrein k bs charging port pr sunlight fall ho, ziada heat bhi na hone dena mobile ko.
insha'Allah within 30 min sb set ho jaega.
Ho skta hai aapk charger ki pin mei bhi moisture aa chuka ho (mobile port ki wajah se) to Usk liye better yehi hai aap testing k liye koi new charger try krien. Mtlb mobile port saaf krne k baad purana wet charger na lgaana. warna port mei dubara moisture aa jaega.
Charger ko bhi CTC se saaf krk. Dhopp mei rkh dein. 3-4 Hours mei wo bhi sookh jaega ache se.
ahsanmughal159
Bro iskay charging port ma water chla gya isko dry kro
RANA_NAJAM
Cable change kr ly. Faulty cable sy b ye issue ata ha. Mry sath b ake dfa asa hoa tha. Cable ki ake side yehe error dti the r dosri thk sy kam krti the. Agr charger thk ha r moisture ni ha ti ye paka cable ka msla ha. Try another cable. Original ya kisi achy brand ki cable use kr k dekhy.
(Msla hal ho jay to kindly isy solution marked kr degye ga.)
FazalHussain
Bhai, go to settings, search fast charging, disable it . Then plug the charger.. theek ho jaye ga.
