Charging Issue...
(Topic created on: 10-15-2025 10:40 PM)
MH_SAKIB
My S20 5g has an charging issue likely phone always inputs in 3-4voltage & 8-13watt....
Charger ANKER 313 GaN 30w PD & cable use or original 5A...
what can I do now?
4 Comments
MonK11
Has this problem started recently or are you using this changer for the first time?
Samsung uses PPS charging standard, so if the charger doesn't support PPS it'll charge the phone at lower power and there can be heating issues as well.
MH_SAKIB
I'm using new Anker GaN 30w PD charger no heating issue but slow charge problem
cs_member10
Dear Samsung Member,
● Kindly check connectivity & charger functionality: Please check whether the charger cable and adapter are fixed well. Remove the charging cable and reconnect with the mobile phone properly.
● Kindly check the charger functionality with a different device or try to charge the same device with a different charger.
● Kindly open Device Care from Settings > Battery > Please tap on 3dots (more option) at the top right-hand side > Please select settings> Enable fast cable charging.
● Kindly disable the battery protection mode( if enabled).
● Kindly follow the standard charging procedure. Charge the device in switch-off condition for a minimum of 10 minutes.
● Please check the back panel of your device's physical condition (Bulge, Swelling, or visible damage).
● If the physical condition is not good: Request you to turn off the device immediately and please do not try to charge or tamper with the battery also request you to visit the service center immediately.
MH_SAKIB
Thanks
