rap1021
I am looking to buy usb type A to type C cable from Samsung online store.
The cable is 1.5m where as the oem cable we get in the box is 1.2m.
My concern is will the 1.5m cable reduce voltage or amps and charge slower than oem cable..???
5 Comments
codie
No it wont but just be sure you buy cable that supports fast charging
rap1021
Yes, i am buying it from Samsung website
PunjabAgricultureIN
But maine buy ki thi toh 1.5m ki thi
Won't make a difference as the size difference of 0.3 m is negligible for a USB charging cable.
rap1021
Ok
