Resolved! Solved
Camera shutter sound disable
(Topic created on: 02-08-2020 05:13 PM)
ArryKam
How to disable camera shutter sound on s9,android 10?.
2 Solutions
Bro, there is no official way to turn off camera shutter sound..only way is to mute your device sound or system sound while taking photographs
or
use Bixby routine if your device supports it
immi007
Keep your phone in silent mode or in vibrate mode. No option to disable the shutter sound.
8 Comments
Ragulraja
Same question is there for me on S10 lite!!!
or
Jameslfrees
Yes there is, I is in the camera app itself. OPEN CAMERA TAP GEAR SCROLL TO BOTTOM SHUTTER SOUND GOGGLE
BUT SAMSUNG CHANGE THE SOUND FROM SHUTTER TO A BA BEEP SOUND.
Its not available in any of the samsung Indian devices(due to some EU Laws)
Members_fWeFJQz
There is no option showing like"shutter sound" so can't disable the sound during taking photographs....what I feel, the only way to turns of the shutter sound is to mute the photo during clicking the picture.
immi007
hedgehog
NimStaff
This is so stupid - Samsung S20 (EU) doesn't have a shutter sound toggle button. I don't want to have my phone on mute all the time just so when i take photos it doesn't make that sound. AND the sound itself makes it seem like there was a fault or failure. So much stuff I dislike about the S20 functionality compared to my old S8
