Camera shaking sound
(Topic created on: 12-04-2024 08:54 PM)
jsanish
Anybody notice the Samsung S24 Ultra back camera making a shaking sound? And while zooming, I hear a lens-changing sound. Is this normal?
5 Comments
Abhirx
Yes, its adjusting focus. Its not camera its sensors
jsanish
Yes I feel sound when focus adjusting
Hitav
Bro it's normal. The sound coming from the camera while shaking is the sound of OIS which stabilize the image. Main 1x lens, 3x and 5x lens has that ois in s24 ultra.
Hitav
If you are satisfied with my comment then please tag my comment as resolved
cs_member10
Dear Samsung Member,
● Kindly check the physical condition of your camera lens.
● Kindly disable the Shutter sound.
Path: Camera app> Settings> Swipe to and tap the switch next to the Shutter sound to disable it.
● Use a microfiber cloth or a cleaning wipe to clean the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
