05-13-2025 08:35 PM in
After the One UI 7 update on my Samsung Galaxy S24 Ultra, the camera quality has significantly dropped. Images are now pixelated and lack detail, even in 12MP, 50MP, and 200MP modes. The sharpness and clarity that made the S24 Ultra’s camera stand out are gone. Everything looks overprocessed and lower quality compared to how it was before the update. Samsung needs to fix this, as the camera no longer performs like a flagship.Fix this with a software update as soon as possible.
05-13-2025 08:43 PM in
Galaxy S- Mark as New
05-13-2025 09:50 PM in
05-13-2025 10:02 PM in
05-14-2025 10:16 AM in
Galaxy SDear Samsung Member,
● Kindly check the physical condition of your camera lens.
● Use a microfiber cloth or a cleaning wipe to clean the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
07-05-2025 07:13 PM in
05-14-2025 12:49 PM in
05-20-2025 09:20 AM in
07-05-2025 07:12 PM in
