Camera focus issue s22 ultra
(Topic created on: 05-02-2022 12:07 PM)
Kmen92
Is any one facing this issue once you click a photo with 50x zoom the image clicked is very very blurry and there is some issue with the camera focus and once you go to the gallery and open the image followed by zooming it becomes clear is it normal
8 Comments
Yes to a certain extend its alright but can't say yet. Cause at this zooming level, it's mostly the AI that does the work.
Kmen92
Are you facing the same issue or else can you try if you don't mind
Kmen92
Hi brother this is the exact issue that I m facing
Can you please tell me is it normal or should I visit samsung store
mKami
I just tested in room light till 80x and it is fine
mKami
Can u check if you are facing same issue in outdoor. This may be improper light in room. Also check if latest software updates are installed. Also do u have 8gen 1 model or exynos
Kmen92
Sure will check in proper light but ideally this should not happen I have tested before also it was fine . I have 8gen 1 model
Samsung_specialist
Hi,
For assistance, please visit one of our authorized Service Centers to check it for you. You may refer to the link it will guide you to the nearest service center to your location https://www.samsung.com/ae/support/service-center/
Kmen92
So that means there is a problem in my phone as I have been told to visit service center
