12-19-2024 10:52 AM in
Galaxy S- « Previous
- 1
- 2
- Next »
12-19-2024 03:07 PM in
Galaxy S- Mark as New
12-20-2024 11:53 AM in
Galaxy SDear Samsung Member,
● Google have recently released a new August Google Mainline addressing Camera failed issue. you can easily install this update through the Google Play System Update option on their device.
Path: Here are the steps to follow: Go to Settings > Navigate to Security & Privacy >Select Update >Choose Google Play System Update>Restart your device to complete the installation.
Note: This will ensure that your device is updated to the latest Mainline version.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
12-20-2024 12:05 PM in
Galaxy SI think its hardware issue, as i can show u the mail proofs , am facing this issue since may 2024 .
02-01-2025 01:24 PM in
- 1
- 2
- Next »
