Calling out S24 base model users
(Topic created on: 02-28-2025 04:51 PM)
Vishavnath
It's been 1 year after the realsed of S24, can you tell me is it worth it to buy after 1 year, I'm concern of EXYNOS how it ?? Is it good in managing battery, performance. Plz share battery information. Atleat can i get 4-5 hrs using aod, 120 hrz (adaptive), data, wifi, bluetooth always on, ideal drain battery ? Or should i buy S23.
3 Comments
Nicolous
Buy other Brands
KUMARdeepesh
You can buy the s23 plus discounted it has snapdragon and same camera as s24 need not to go for s24 hope it helps pls mark resolved and like.
cs_member10
Dear Samsung member,
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
