Caller background problem S22
(Topic created on: 12-05-2024 02:38 PM)
AliAOmran
Hi
After last update .. the caller background doesn't show profile picture along with the background like the image below
Only the background showing
4 Comments
AliAOmran
Didionpc
Update the Call Background:
Open the Phone app.Tap the More options icon (three vertical dots).Select Settings > Call Background.Tap Background, then choose a picture or video from your gallery or the featured options.
Re-add the Profile Picture: Sometimes, re-adding the profile picture can help.
Go to the Contacts app.Select the contact whose picture is missing.Tap Edit and re-add the profile picture.
Restart Your Phone: A simple restart can sometimes fix minor glitches.
If these steps don’t resolve the issue, it might be a bug introduced in the latest update. In that case, you can report it to Samsung support for further assistance.
AliAOmran
Thank you but unfortunately nothing has helped
Didionpc
Then its batter to use lve chat option in this app support section.
