Resolved! Solved
Call forwarding issue
(Topic created on: 10-23-2025 07:41 PM)
pbonde
On S24 getting Vodafpne idea call forwarding issue error shows some thing went wrong
Can your sim network mode to 3g auto or 2g only to check call forwarding status
6 Comments
pbonde
VI call forwarding working only on 2G network and due to enable Auto Blocker 2G network not working now issue is resolved
For me I can check call forwarding status in Vi 4g network but network didn't gone to 2g network for checking call forwarding. This issue is present for user specific.
vinayshah
Expert Level 4
Typical error.
Go outside in balcony or some place where network is proper, turn wifi off and try. It should work.
cs_member10
Dear Samsung Member,
As we have checked you have mentioned that your issue has already been resolved. If you have any further queries please feel free to get in touch with us.
Abhishek8118
When i am trying to turn it off by ceds it is showing network problem or wrong mmi code and after many and many attempts from all side i cant turn it off
