Bluetooth device battery percentage
(Topic created on: 06-15-2020 11:27 AM)
AbhijithSuresh
in one ui 2..1 the Bluetooth device battery percentage is  not  visible  in  notification  panel..
Each  time  u need  to  check  the  battery of  Bluetooth  device  u  need  to  go to  Bluetooth  settings  and  check for all connected  devices
Is there  any  simple way to  show  Bluetooth device battery percentage  in  hone screen or notification  panel
Or
Will Samsung  include the  feature  in  coming  updates
4 Comments
Not applicable
no ...only 3rd party app like 'baton' can perform that.....in goodlock apk quick panal star option is there but not sure can it show battery percentage or not
no no have tried that one tooo
It Does Show Up In Your Notification Panel .
Just On Click on Bluetooth Text Label
It will show All Your Devices.
Connected Devices and Their Battery Life.
yes that's wat I said is there any way to view them in the notification panel
