Bluetooth connection issue
(Topic created on: 12-07-2024 11:12 AM)
TrafalgarDlaw
Anybody else having issues with s24 ultra Bluetooth connecting?
5 Comments
Yanca
I'm having problems with Bluetooth connection eith 35s
Test in Safe Mode
Boot the phone into Safe Mode (press and hold the power button, then tap and hold the "Power off" icon and select Safe Mode).Test Bluetooth. If it works in Safe Mode, a third-party app might be causing the issue. Uninstall recently installed apps.
Or reset network settings
Go to:Settings > General Management > Reset > Reset Network Settings.
Or Clear Bluetooth Cache and Data. Go to:Settings > Apps > Bluetooth (use the three-dot menu to show system apps).
Tap Storage > Clear Cache and Clear Data. Restart your device reconnect your Bluetooth
Or Forget and Re-Pair Devices
Go to Settings > Connections > Bluetooth.Find the device in the list, tap the settings icon , and select Unpair or Forget.
