SJS07
05-09-2021 12:38 AM in
I have observed a blue edge light which is not like the edge light that goes along with the edges of the phone ..this blue edge light just lightens the edge where the navigation on screen buttons are there. This usually happens when I will be playing games like COD. Can anyone tell why is this or what is this ? My handset is s10e
Solved! Go to Solution.
Sidhabhi
05-09-2021 12:41 AM in
That's game launcher temperature monitoring feature, need not to worry..
It's temperature monitoring. When enabled it shows that blue bar. It tunes brightness and CPU speed to lower temperature
4 Comments
Sidhabhi
SJS07
05-09-2021 12:42 AM in
Hey thanks for the information. That helps 🙂
Dr_Interchupipi
05-09-2021 09:28 AM in
Game launcher heat regulation
Myso
01-26-2023 02:08 PM in
How to recover the blue light ?
When the blue lights appear my phone also heat
