05-05-2024 12:15 AM in
Galaxy Sgot my phone yesterday. It had 50 persent bettery used for arund 3 hours. And the bettery dropped to 35 and 30. The specifications says that the bettery can last for 2 days. From that percepective this bettery consumption rate doesn't sound like a good thing. The phone didn't came with a charger So orderd a new one. it is gone take time to arrive. This is my first time buying phone in this range. I am a bit skeptical about it. My technopop pop 5 lite has a better bettery timming then it.
I am just hopping that it just first time charging problem. If anyone knows about this then please let know. I genuinely like samsumg products. it will be very disappointing if this phone is having this problem for real.
05-05-2024 06:27 AM in
Galaxy S- Mark as New
05-05-2024 06:51 AM in
Galaxy SHere's what you can do:
* Keep an eye on your battery usage for a few days and see if it gets better.
* Turn off stuff you're not using, like Bluetooth or location.
* Close any apps you're not using.
* If it's still draining fast, reach out to Samsung support.
