12-02-2024 12:52 AM in
Galaxy S- Mark as New
12-02-2024 12:59 AM in
12-02-2024 01:33 AM in
Galaxy SDisable Unused Feature & Turn off Bluetooth, Wi-Fi, and Location services when not in use.
Disable Always-on display or reduce its duration.
12-02-2024 05:04 AM in
Galaxy S1 Enable adaptive battery
2 Disable AOD
3 Display - Natural
4 Performance type - Light
5 Disable background scan
6 Switch off Bluetooth
7 Discharge battery fully and recharge
8 Use dark theme
9 Disable animated wallpaper
If this reply answered your query please mark my reply as "resolved" by clicking 3 vertical dots on top right of my reply. Thank you 😊
12-02-2024 07:54 AM in
12-02-2024 07:56 AM in
12-03-2024 10:39 AM in
Galaxy SDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
12-03-2024 10:44 AM in
