Battery
(Topic created on: 3 weeks ago)
dusty90
My battery goes down so fast when I just use spotify , when I used an iPhone the charge went down 2% in 30 minutes but in my samsung s23 it goes down 10% in 30 minutes, is there anyway I can reduce my battery consumption while using only one app
2 Comments
MOQBALI
Expert Level 3
• To reduce battery consumption while using Spotify on Samsung S23, disable high-quality streaming in Spotify settings, optimize Spotify for battery usage in device settings, limit background activity for Spotify, close unused apps, use battery saver mode, update Spotify and the phone's operating system, and check for rogue apps that may be draining the battery.
pro123down
Wait for an software update or try turning on power saving mode
