Battery
(Topic created on: 04-30-2024 10:43 PM)
charleswise
What could be the problem if your Samsung Galaxy s8 phone is charging too fast and you have not enabled fast charging and you are not using a fast cable charger.the problem is its charging too fast to be considered normal, sometimes it goes from 0% to 80% in 30 minutes then it stops moving at 80% or it just moves to slow like it doesn't even reach 100%.but when it comes to battery life it drains even faster than it charges which doesn't make sense cause the battery is new.what could be the problem
8 Comments
ElNino7
It means your battery needs to be changed
charleswise
But I just replaced the battery
Not applicable
It's an old phone, of course it'll have issues
Not applicable
Not all old phones have issues.
Not applicable
Could be a hardware problem, like a component from the power circuit on the main board has failed or is failing.
Erling
Maybe buy the latest Samsung
Erling
The s24 ultra
SamsungComm1
Thank you for reaching out charleswise.
Pleas test your battery health
Open Samsung Members App and tap "Support" on the bottom.
Check your battery status through "Phone diagnostics".
Tap "Test all".
