Battery usage issue
(Topic created on: 05-26-2025 09:14 PM)
Bert1788
Been on the UI 7 for almost a week now and I must say, the battery issue is really a thing.
I'm getting less than a day on one charge on my S21 5G.
I just saw on my Google feed there might be a software update on this matter which can be good hopefully. Other than that, we do have a few glitches here and there I noticed some things don't line up well which I'm sure will be on a future update, but so far so good besides those issues, one UI 7 is looking pretty good my end. I use good lock for some enhancements but ever since the update I've turn a few features off on the platform.
3 Comments
Munatsi399
It's still to be rectified, some devices are facing that challenge
Bert1788
Quick update on the battery issues.
For now, the best solution I've come up with which seems to be working fine, is unfortunately turn off 120hz display.🥴😒. I've been using mine and honestly I don't mind it so far, plus my battery is surviving now. I also set my AOD to turn on automatically which for some reason Samsung removed that automatically did turn off in a dark environment. As it is my last charge was 6 hours ago and I'm sitting on 58%. It's helping. Just my opinion on that matter, till we get the update which I understand will fix the drainage issue...
Bert1788
Hie S21 fam. Not sure what's happening but I got this "security" update today. Not sure if it's the one to update and or address the battery draining issue but it's out there. Manually check your updates if it hasn't appeared on your notifications yet should download right away. Build number ending with FHYE1.1748864371564.jpg
