Battery usage details not present in s20plus
(Topic created on: 01-04-2021 02:27 PM)
AJ1408
Recently I have noticed that whenever I try to check the details of battery usage since last charge it comes up blank. There is no screen on time detail or the battery drain graph available. Also no app usage details are present. Is someone else facing the same issue with their s20plus or other devices.
6 Comments
Same here and no fix worked for me.
PANKS1
reset phone or factory reset
PANKS1
happened with me...did factory reaset and graph came back after 3 days
Skywalker
update the app from Galaxy store
I just did..
stats are back
Samsung_Support1
Dear Samsung Member,
Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
