Battery protection
(Topic created on: 07-03-2024 12:23 AM)
M3N1990
Hi dear,
I have s22+ with on ui 6.1
In Battery protection setting,
If I used adaptive, is it temporary will be on basic mode until it recognise my sleep pattern?
Or it will be like Off untill it recognises my sleep pattern then will start switching between basic and Maximum?
4 Comments
sms222000
Adapter
Mosh47
If you got to customization services then activities and interest, you can see your sleep pattern is recognized or not.
GalaxyNerd
It will learn your habits such as when you use the phone mostly and when you sleep based on that it will charge slow and fast
Samsung_specialist
On your Samsung Galaxy S22+ running One UI 6.1, the "Battery Protection" setting includes features like Adaptive Battery and Performance Profiles which aim to optimize your device’s battery usage and performance based on your habits and usage patterns.
Adaptive Battery uses machine learning to recognize your phone usage patterns and prioritizes battery power for the apps and services you use most frequently. It helps extend battery life by limiting battery usage for apps you don't use often.
Initially, it’s not strictly on Basic mode but rather operating without bias towards either mode. It's gathering information and might not aggressively save battery or prioritize performance until it has enough data.
