Battery problem
(Topic created on: 3 weeks ago)
MUKESHMADIYA
The battery is draining rapidly after the One UI 8.5 update. S24
2 Comments
huntwithnihal
Give the phone sometime to adjust and integrate with the new UI as per your usage. For immediate solution, limit battery charging to 80%
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select "try another way"> Next > Enter a new password > Next
