GrayBugIII
01-17-2018 03:22 AM in
hello i bought my phone just month ago today i noticed that my charger was connected for more than and hour but when i came it was at the same level and not charging,
i pick up the phone bend chord a little and it got connected and i release it and it get disconnect .
this is the moment i feel really pissed that what's the outcome of buying such an expensive phone and you're getting this type issues eith orignsl charger .
is it mobile charging port fault or charger chord fault ?
i had used other cable it works at first but soon it become loose later..
anyways i want to get rid of this ..
so tell me what's the easiest eay to fix it
also tell what will be the cost i have to pay in Karachi Pakistan for any hardware repair solution if needed .
needed detail satisfied answer please
thank you !
thank you !
2 Comments
3mo0or
01-19-2018 08:02 AM in
It's has to be fixed under warranty
GrayBugIII
01-19-2018 12:45 PM in
my set was without warranty
