Battery optimisation
(Topic created on: 06-24-2025 10:19 PM)
AnujMuley
What is samsung doing. I own a S23 FE and today i charged my phone to 100% in morning and now its on 40% with location on + WiFi all day and profile to standard with 120 hz which is very good battery life. But when i charge my phone to 90% or 80-85% the battery life is truly shittt i have to charge 2 times a day. I am uploading the screenshots and all days with same usage 2hrs netflix or prime, 2hrs of youtube, 10-15 mins of instagram, 30-40mins of whatsapp, 30-40 mins of brave(search and browsing). Today power saving mode turned on at 40% can be seen in screen shot. Please samsung fix battery issue in S23 FE and S23 series please!!!
10 Comments
y682
Put unused apps to deep sleep, your battery seems fine
AnujMuley
Yes bro all the apps are in deep sleep.
saktiprasad
Brother am getting only 3 h 30 m with the full battery even am not using that much as you
AnujMuley
Try reseting the device or perform clear cache partition
saktiprasad
Done everything, no solution for this
AnujMuley
BiRdMaN
This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others. Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
BiRdMaN
It is a BUG send an error report along with log files to customer support through this members app and Samsung will fix it in the next update. To do that follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful please Accept it as a solution Thank you 😊
cs_member10
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
