Battery low notification
(Topic created on: 01-20-2021 12:06 PM)
User28
Has anyone observes that even the battery low notification is also popping up on the screen with the same edge panel lighting effect. Any way to disable this? This started after the one UI 3.0 update. I am using S10.
4 Comments
Goto Notifications 》 Brief Pop Up Settings 》 and disable Settings and Device care.
If that helped or solved your query "Accept as solution" will be appreciated.
User28
How do we exclude system notifications from the edge panel lighting effect? I tried to turn off but they are disabled.
User28
I see this screen.
brackmann
Beginner Level 3
I am having the same issue. After installing a new battery, the keychain keeps notifying me.
