09-15-2020 08:45 AM in
Galaxy S- Mark as New
09-15-2020 08:52 AM in
09-15-2020 08:54 AM in
09-15-2020 08:55 AM (Last edited 09-15-2020 08:55 AM ) in
09-15-2020 09:43 AM in
09-15-2020 09:05 AM in
09-15-2020 10:18 AM in
Galaxy Sbut you can do some settings if you not done yet to save more battery life
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
3. Long press on each app specially 3rd party(LIKE FACEBOOK, INSTA,YOUTUBE) and rarely used and ON "GOOGLE APP" as well then click on>app info> then go to these 3 options below on by one
4. Device care>battery >power mode>select "optimised" and "adaptive power saving".
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
5. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder.
6. If you use Facebook frequently then disable "auto play video"
And if you are mostly uses mobile on wifi connection then also disable "auto play videos" in YouTube.
09-15-2020 10:19 AM in
09-15-2020 10:24 AM in
09-15-2020 10:25 AM in
