Battery life is taking a toll
(Topic created on: 02-05-2021 11:02 PM)
Members_mInJv8B
Battery life has been deteriorated more than ever after the January security patch update. Please suggest any tips which are not suggested earlier on this page
5 Comments
Ehsank
if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
pkv3218
one of the best ....🙏🙏🙏🙏🙏🙏🙏
Ehsank
KanjiKher
thanks man very useful tips....
Ehsank
my pleasure 👍👍😊
