Resolved! Solved
Battery learning usage pattern issue
(Topic created on: 12-14-2024 01:17 PM)
Afsarkhan85
Recently I had done factory reset on my Samsung s22 device. Battery is draining fast and showing learning usage pattern .
Is there is any problem in my device..?
Resolved!
11 Comments
goodthings
Your's most welcome to here.
cs_member8
Dear Samsung Member,
We regret to hear about your experience with our product.
To fix battery drain issue please use the link to perform some easy troubleshooting steps: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps:
3. If you do not remember then reset (Forgot password) your Google account.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
