02-26-2021 11:05 AM in
Galaxy SI owned a galaxy s21 series phone for my wife. I tried to start using from yesterday and it's battery is drastically draining. I cant even complete even 2 hours call. Done all updations. 4000 mah battery new phone two week old great invention from samsung.
02-26-2021 01:11 PM in
Galaxy S- Mark as New
02-26-2021 01:25 PM in
02-26-2021 01:53 PM in
02-26-2021 02:43 PM in
02-28-2021 11:46 AM in
Galaxy SAlso, I hope you do not leave the charging cable connected even after your phone has charged.
You can try the following
Go to Settings > Apps > Select all apps one by one > Battery > here make sure under "Optimise Battery Usage" it says "Optimising Battery Usage" and not "Not Optimising"
You can change it to "Optimising Battery Usage" by just clicking it and switching the toggle
Next turn off "Allow Background Activity" for the apps you use the most
If the above does not help
Try Resetting and/or Hard Resetting your phone
Try using you phone in Safe Mode and see if the problem still occurs
Hope this helps 🤞🏻
02-28-2021 11:57 AM in
03-02-2021 10:16 AM in
Galaxy SKindly be informed that Battery consumption depends on phone usage. However, to reduce battery consumption you can kindly try below advises:
• Turn off Wi-Fi to save the battery when not in use.
• Change the screen resolution. It is set to FHD+ by default. Higher resolutions make the display more vivid, however they will consume more battery power.
• Use Device Care. The device Care feature provides an overview of the status of your device’s battery.
• Change Power saving mode. MID: Activate power saving mode to extend the battery’s usage time. MAX: In maximum power saving mode. The device decreases battery consumption by applying the dark theme and limiting the apps and features available. Network connections, except for the mobile network, will be deactivated.
• You can save battery power by preventing apps that are running in the background from using battery power when they are not being used.
• Tick apps from the apps list and tap SAVE POWER. Also, tap MENU → Advanced settings and set the App power monitor options.
• Also if you are in a weak network area try to move to an area with a good network signal to avoid battery consumption.
Note: The battery capacity and lifetime will reduce if it is overcharged often, the battery can be charged and discharged hundreds of times, but it will gradually wear out. Battery charging time depends on the remaining battery charge and the type of battery and charger used.
03-02-2021 10:35 AM in
03-04-2021 05:48 PM in
Galaxy Sif most of the users in fact all users have same issue than definately there is something common issue.
i have purchased phone just 4 days back
