Battery issues
(Topic created on: 12-08-2024 02:26 AM)
Abhi_s2599
Dose anyone face battery issues in s21fe
2 Comments
s21fe2021
S21fe battery drain problem 🔥
cs_member8
Dear Samsung Member,
We want to inform you that it is our best endeavor to provide you with an impeccable product experience at Samsung. Our products pass through rigorous quality checks which are globally recognized. As of now, there are no reported issues with Samsung devices.
If you are facing the battery drain issue on your device, kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
