Battery issues
(Topic created on: 08-05-2024 10:44 PM)
Larry1810
Hi, My S24 Ultra's battery draining much faster than usual. It started after I did the latest software update this morning. Also to add, the phone's usage is the same as usual. Please help with this issue.
7 Comments
9547937312
Maloy das
Gouthamram
Disable unused system apps & use original chargers
Coffee_Cat
It's not a new Issue 😞 ultra series still struggling with serious battery drain.
You can try once with The code *#9900# provides access to the "SysDump" mode on Samsung devices,
And reset the battery stats.
Sameer
Making few changes can enhance battery life to a greater extent ..
Making the following changes as shown in the video ...wait for few weeks for the phone to study the usage patterns and you will see an improvement in battery life
https://youtu.be/DXM7pdW5a-w?si=cXv4W6zVL3JvVBqp
Also make your phone run 2x faster.
https://youtu.be/pgNi1Pmua3c?si=HvJhiGglU77saHG9
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
