Battery issue after update to Android 12
(Topic created on: 01-18-2022 09:57 PM)
SumeshS
battery is consuming more post android 12 update. Any idea to get it solved.
4 Comments
Hualngo
Which model
SumeshS
S20 FE 4G
Hualngo
SAME here, hardly get 6 hrs S.O.T with 60hz .
Before I USED to get atleast 7.30 hrs
cs-member13
Expert Level 4
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
