Battery issue after Android 12 update
(Topic created on: 01-27-2022 06:59 PM)
JP_Jangir
After the software update my phone's battery is draining much faster. Please fixed this issue.
My mobile is samsung galaxy s10 plus..
4 Comments
rap1021
Almost every S10 owner is facing this issue. Please send error report to let Samsung know so that they can fix it in the mext update.
Everyone facing the same issue bro.
AjitMori
I have same issue
cs-member13
Expert Level 4
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
