Battery issue S21ultrs
(Topic created on: 06-11-2022 01:24 PM)
bnuc
I'm using S21 ultra and now a days facing serious battery issues...draining too quickly..with a screen on time of 4 to 5 hours..I'm getting 16 to 17hrs on a full charge. Pls suggest any solution.
3 Comments
VikrantTambade
Hi,
I am also a S21Ultra user since more than a year now. And I am getting around 5-6 hrs screen on time since start. I will be mostly on wifi and very mild on data connection. I have the necessary battery settings ON. I am not finding any changes after recent updates.
You may check which app is consuming more battery then clear it's app cache. And can also put apps on sleep or deep sleep which you are hardly using.
Good luck 👍
shiv7688
Please share the battery stats to better understand the reason.
Samsung_specialist
For assistance, please visit one of our authorized Service Centres to check it for you. You may refer to the link it will guide you to the nearest service centre to your location https://www.samsung.com/ae/support/service-center/
