03-16-2017 12:13 AM in
Galaxy S- Mark as New
03-16-2017 04:06 AM in
Galaxy Si sold the crap.. now s7 edge
..best. happy to have a full charge fone ..put s6 in the rubbish
03-16-2017 07:19 AM in
03-16-2017 02:17 PM in
Galaxy Smy phone is s6 edge and here is what i did to make sure battery will work fine after the nougat update
it's all about the new firmware reads wrong battery stats from the older firmware .. so you will need to do the following and trust me you will notice the difference
1- back up all your files and contacts
2- charge the battery to 100% and keep unplugging and plugging till the LED becomes green all the time .. this step is to make sure the battery is fully totally charged
3- shut down your phone
4- press Home+power+Volume Up .. that will bring you to recovery mode .. then connect your phone to the charger again
5- choose hard reset and click yes
6- after you set your phone and add your google account and all use your phone normally till it goes to 0%
7- charge it all way back to 100% .. that's it .. now you have a recalibrated battery and you will notice the difference
if i can upload screenshots in the comment i will show you that i got 3 hours screen on time using only 50% .. i will post one so you can see make sure you check it
03-17-2017 04:19 PM in
03-17-2017 04:36 PM in
03-17-2017 04:37 PM in
03-28-2017 01:37 AM in
03-28-2017 01:38 AM in
