Battery draining
(Topic created on: 03-20-2020 08:56 PM)
khan69
My S8 battery is draining like hell after the march security patch update. It went from 14% to 1% in 2 hours when idle.
Is it normal after software update ? Or do I have to make any changes in the settings?
4 Comments
_007
Expert Level 4
Check for running 3rd party background apps from  developer mode>Running services>Force stop unnecessary apps.
If battery is too old consider replacing it or check battery health in service center or by accubattery app.
M1A1
Software updates, when the phone is 3 years old, are sent to make it feel laggy so as to prompt you to buy a new phone. Its the harsh reality with many smartphone manufacturers.
khan69
is it true ?
M1A1
I have experienced it. In my opinion, its true. Please check with others too.
