3 weeks ago in
Galaxy S- Mark as New
3 weeks ago in
3 weeks ago in
3 weeks ago in
3 weeks ago in
Galaxy SI did the following..
- Cleared cache data from system recovery.
- Cleared app cache
- Deep sleep unused app and rarely used app.
- Clear cache of One ui home app.
- Reset network if there are any trouble.
3 weeks ago in
3 weeks ago in
3 weeks ago in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
