3 weeks ago in
Galaxy S- Mark as New
3 weeks ago in
3 weeks ago in
3 weeks ago in
3 weeks ago in
3 weeks ago in
Galaxy SAlso changed settings and tried but battery drain is too very fast
3 weeks ago in
3 weeks ago (Last edited 3 weeks ago ) in
3 weeks ago in
Galaxy SDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
