Battery draining too much
(Topic created on: 02-17-2024 11:40 PM)
itxmumar
My S22 battery is draining very fast. I charged it 100%  and use tiktok for 5min and 1 hour on standby it used 10% of  batttery. When i first purchased it gives 4 hours battery time on 90fps game(pubg)now after 4 months it is giving 3 hours of battery time which is very bad.
Any solution ?
Will samsung replace my battery because its under warranty?
4 Comments
itxmumar
Power saving was also active
Zarrar26
Make sure you're using good quality charger, not 500rs one.
itxmumar
I am using xiaomi original charger
Billydot
I am facing similar issue since last 2 months. Drainage is a bit quick now. Maybe some bug
