Resolved! Solved
Battery draining issue after updation of May 24 security update
(Topic created on: 05-21-2024 07:51 AM)
alokela
After updation of May 2024 security update I'm facing rapid battery draining issue.Today morning while I open my phone the CONTACT STORAGE SECTION uses 4 percent battery.
Actually I don't know what's this section ?
Screenshot attached
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution . Thanks.
12 Comments
alokela
There's no solution found on above links.
Don't miss lead to customers or members.
Those who given their suggestion first of all check your phone also.Then give any suggestions
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
alokela
It's not easy to reset factory data everytime, why not samsung fix this issue at their end through software ?
goodthings
Ok, as you like. Thanks.
goodthings
alokela
Ok
goodthings
Your's most welcome.
The best thing to overcome draining issue is GO TO SETTINGS > APPS > GOOGLE PLAY SERVICES > PERMISSIONS > CONTACTS ( DON'T ALLOW).
CONTACT STORAGE is draning battery from here.
alokela
Finally I got the sollution of BATTERY DRAINAGE issue in galaxy S24 series.
I've added the sollution as screen shot for all.
To stop battery drain in contact storage on a Samsung Galaxy S24+, you can try these steps:
Go to Settings
Select Apps
Select Show system app from the three dots on the right side
Go to Contact storage app
Select Battery-restricted
