BeastSlayerr
I have been using samsung phone as my daily driver since s3 days.I have used every flagship from then every year.I love samsung because it has good camera than oneplus & apple too & also beacuse of Its UI which dont have many bugs like oneplus.But from s10 + & now s20+ plus battery charge is keeping very low.I am getting 3 .5 hrs to 4 hrs sot which is very less.Even my 2 yr old oneplus 7 pro give 5 to 6 hrs of sot.I always charge my device from 30 to 96 % never ever drained much or charged much.I keep on checking it timely still so less time.I think its time to switch from samsung till they make exynos chip for flagships.Settle down with oneplus is good now..
17 Comments
pjS20plus
Same issue with me. I m getting .3 hours and also i need to charge it 2 times in a day really bad performance from s20+.camera also lagging.
ravi5
Same with me i am getting around 4 hours of SOT on full charge
BeastSlayerr
Yes bro one ui 3.1 is even more bad than 3.0.Sot is too bad never ever buy any samsung flagship if they are exynos.Custom chip which was used in exynos by samsung is battery hungry .Now they remove that but still exynos is behind qualcomm counterparts.Now my call ui is also lagging
Ehsank
This screen on time is from 100-0 %?
BeastSlayerr
I never drain battery to 0 percent.Neither anyone does drain that much.Draining to 0 also affects battery health.i always charge at 31 %
Ehsank
So once full charge and use upto 1-2 % to check exact sot thrn you would know exactly
BeastSlayerr
Bro max it can give 1 hr more whats the use when screen brightness will go then & cant use the phone like that..Still it is much behind the competitions.I did check 2 times but not that worth.
BeastSlayerr
Bro this all are old method..Also done this much before..Still doesn't work..When battery is consumed by chip these methods wont work..Custom chips used in exynos are the sole reason for battery drain
Ehsank
