Battery 🔋 drain
(Topic created on: 05-14-2025 02:11 PM)
teli5
Beginner Level 3
S23 fe battery drain i charge 4 times a day after the ui 7 update
12 Comments
Munatsi399
Someone had his battery drain issue fixed by updating one UI home on galaxy store
I updated mine yesterday still no changes....but I get to last 14-16hours a day on heavy use on 95% charge
Munatsi399
That's good battery life on heavy use.... is it not?
I used to hit 18-24 hours on heavy use though
Munatsi399
Yeah, there's a lot of staff that runs in the background with UI7, you might need to check your background usage, as there are apps always running in back ground, and restrict accordingly
Goodlock modes use a lot of battery
Munatsi399
There are a lot of amazing features that if you're carried away, you pay in battery life
TMEN12
I'm charging like 3x a day since update what's happening guys s24 ultra
Munatsi399
It's still quite a mystery..... some claim if you clear cache your battery life may improve, some claim improvement after updating One UI Home in galaxy store....
I personally haven't experienced battery drain, so I don't know as to what works, but im convinced is it's a bug, a bug fix is coming soonest
