Battery drain
(Topic created on: 05-08-2024 04:34 PM)
Jayster
Anybody else experiencing crazy drain after the newest update for s23 ultra?? Even of the phone is on for a few minutes it drains a lot she this was never an issuebefore the update..
6 Comments
Go to Settings > Battery & Scroll down to see which apps in Battery Activity are draining your battery. Put unused apps to sleep, and Restrict or Optimize the ones that are draining it.
Jayster
Thanks but I've already done all that most of my apps are below 3% usage so I'm guessing it's the update. Cuz just on standby it loses power which never happened before the update
You welcome 🤝
Surazmanee
Yes same issue for me. Very annoying. Don't know when Samsung is going to fix this issue.
Samsung_specialist
To address the battery drain concern, we recommend performing additional troubleshooting steps to identify the root cause of the issue. These steps may include:
1. Update Software: Ensure that your device's software and related apps are updated to the latest version. To update your mobile device's software, follow these steps:
   - Step 1: Go to Settings > Software update.
   - Step 2: Tap on Download and install.
   - Step 3: Follow the on-screen instructions.
2. Setup Phase: Your new phone’s battery may initially drain faster as you set up applications and features. This is part of the setup phase, and background operations are optimized during this time. Allow a few days for all background operations and syncing to complete.
3. 5G Service Impact: While connected to a 5G network, your phone may consume more battery than usual due to the high-speed processing of large-capacity data. Consider optimizing overall usage and adjusting background usage limits.
4. Optimization Steps:
   - Open Settings > Battery and device care > Optimize now.
   - Adjust Background usage limits: Settings > Battery and device care > Battery > Background usage limits.
5.  Use adaptive battery: Settings > Battery and device care > More battery settings > Adaptive battery.
Jayster
Unfortunately it's still the same. Is the battery gonna deteriorate with every update 🙄😒
