Battery drain
(Topic created on: 03-03-2022 09:03 AM)
shakira786
Anyone notice a significant decrease in battery life since software update? All my apps are off from background usage as well as screen timeout to 30seconds.... what can the issue be now?
3 Comments
Tsogo_sam05
Hi, shakira786 kindly optimize your device.
1. From the home screen, swipe either up or down to access apps.
2. Tap Settings.
3. Select battery and device care.
4. Tap Optimize now.
If the issue persists, please perform a soft reset of your device.
Press and hold the power and volume down buttons for about 10 seconds.
*The device may take a screenshot, however, keep holding the buttons for a few more seconds.
TabA6
Mine actually got better after update
shakira786
Lucky you
