Battery drain with UI 3.0
(Topic created on: 02-17-2021 08:44 AM)
sandy1402
At present encountering severe battery drains after UI 3.0 Upgrade
8 Comments
Ameenex
which model?
AbhishekPuri
clear cache partition
Step Clear Cache Partition
step 1
Turn off your phone ...Connect your phone to laptop/pc with a type-c cable.
step 2
Press Volume up and power button (also press bixby button if present) at the same time .
step 3
Keep it pressed until samsung logo appears on your phone.
step 4
Then a list of your options will come on your phone..
Go to Clear Cache Partition option by navigating through volume buttons.
step 5
After selecting Clear Cache Partition option,then click power button once.
step 6
Once Cache is cleared you will be taken to first option..Then again click power button to restart the phone!
after that go to device care than battery section and click on background uses limit than turn on put unused aaps to sleep and come back and click more battery settings and turn on adaptive battery.
than come back device care interface and click on 3dot than click on automation and turn on adaptive power saving.
sandy1402
I am using s10. did full format
帕里克
almost everyone complaining of it after update. ui is getting smooth but battery drain fast. almost all series, who got update have thus issue.
M51user
rojon
This has been the case with after almost all one ui updates. Samsung really needs to fix it asap !
帕里克
yes true
Samsung_Support1
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
