Battery drain very fast
(Topic created on: 08-10-2024 01:43 PM)
aryan0707
My phone is samsung s21 ultra After security July software update battery draiing very fast and battery show that is weak . Please help this isuue
4 Comments
Galaxyprime
Try reseting the device if things don't get right, visit service center and tell them it's only after the Update, So kindly check if it's a bug or battery need replacement.
Gouthamram
It takes a little bit to settle down on every upgrade.
Wipe cahe partition on recovary mode.
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
