Battery drain solved in s21 fe 5g
(Topic created on: 11-29-2022 10:04 PM)
sanju9896
So finally samsung has improved battery drain in S21 fe 5g in recent one ui 5 update.
If any member still faces battery drain issue then
I recommend that you should do factory reset after updating to one ui 5.
Do like this post if it helped you.
12 Comments
mr_Kingtiger
The app is inbuilt??
o1eroy
Few devices have this application by default and few needs to download it. You better install it on a PC/laptop. Connect your device to your laptop with a USB cable then run the smart switch. It'll automatically detect the device and install the latest version into the device.
mr_Kingtiger
Okay let me check
