Battery drain #s21fe
(Topic created on: 12-20-2022 11:29 PM)
KarthikVV
Will the  s21 fe 5g exynos battery drain problem get solved. am getting sometimes less then 4hrs sot
7 Comments
Thiru421
I am getting 3 hours only
KarthikVV
My S21FE Same problem
hotRod_23
Yes with the Android 13 update even I am getting only 3hrs of SOT on my S21FE EXYNOS version 😢
Arigh
I am getting 6hrs or more...least I got 5.30 hrs,i charge my phone 100 percent not gimmicky 85 percent...do u use dual sim?
Hitesh29
Agree. Mine is less that 3hrs of sot
cs_member8
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
